Configures a list of I-SID numbers that represent local or remote Layer 3 VSNs to which the IS-IS accept policy applies. After you create the list of I-SID numbers, you must then create, configure, and enable the IS-IS accept policy.
When creating an I-SID list, you can add I-SID entries until the maximum limit for supported Layer 3 I-SIDs is reached. The system truncates any additional I-SID entries. The maximum limit includes the I-SIDs for locally configured Layer 3 VSNs and the I-SIDs specified for IS-IS accept policy filters.
Refresh the EDM tab to view the actual list of I-SIDs in the I-SID list.
Enable IS-IS globally.
Ensure the manual area exists.
- Select IS-IS.
- Select the Isid-List tab.
- Select Insert.
- In the Name field, specify a name for the I-SID list.
- Select Isid or Isid-List.
- Specify an I-SID number or a list of I-SID numbers.
- Select Insert.
Isid-List Field Descriptions
Use the data in the following table to use the Isid-List tab.
Name |
Description |
Name |
Specifies the name of the I-SID list. |
Isid or Isid-List |
Specifies that you either want to add a particular I-SID or a list of I-SID numbers. |
Isid |
Specifies a particular I-SID number or a list of I-SID numbers that represent local or remote Layer 3 VSNs to which the IS-IS accept policy applies. An I-SID value of 0 represents the global routing table (GRT). |
